You can group your WiiM devices with Echo or other Alexa built-in devices to set up Alexa Multi-Room Audio. This feature enables you to play the same audio simultaneously across all devices using simple Alexa voice commands. This tutorial will guide you through the process of setting up your Alexa Multi-Room Audio system.
Alexa groups support only network audio input and cannot transmit audio from other inputs (e.g., Line In, Optical In, HDMI ARC, or Bluetooth) to devices in the group over Wi-Fi. In contrast, WiiM groups created in the WiiM Home app support all these audio inputs.
Step-by-Step Guide
Before Your Begin
  • Set up your WiiM devices properly and connect them to the same network.
  • Set up Echo and other Alexa built-in devices properly.
Step 1: Sign in to Your Amazon Account on WiiM Devices
  1. Open the WiiM Home app.
  2. Go to the Devices tab and select one of your WiiM devices.
  3. Navigate to the Browse tab, scroll down to the bottom, and tap Amazon Alexa.
  4. Tap GET Started and then follow on-screen instructions to sign in to your amazon account on the selected WiiM device.
  5. If you have any additional WiiM devices, repeat the above instructions to sign in to your Amazon account on each one.
Step 2: Group WiiM Devices with Echo or Other Alexa Built-In Devices
  1. Open the Amazon Alexa app and sign in to the same account as the WiiM Home app.
  2. Go to the Device tab.
  3. Tap theicon in the top-right corner.
  4. Select the Combine speakers > Multi-room music option.
  5. Select your WiiM devices together with the configured Echo or other Alexa built-in devices from the list.
  6. Choose a name for the group ( for example, Party Time) and tap Save to complete.
Once the setup is completed, the Alexa Multi-Room music is ready to use.
Step 3: Play Alexa Multi-Room Music
To play Alexa Multi-Room music, you can just say, "Alexa, play music on Party Time" and music will play together on the all devices in the Party Time group.
By following these steps, you'll easily set up an Alexa Multi-Room Audio system and enjoy a seamless, integrated audio experience throughout your home.
