We have found that there are some issues that the app can't find your device or the app can't communicate with your device on Eero. We can try to change the netmask configuration to solve the above issues, please follow these steps in the screen below:
Eero - Discovery and Connection Issues Print
Modified on: Fri, May 6, 2022 at 10:49 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
