WiiM Device's AirPlay Capabilities
Some of our WiiM devices can function as an AirPlay Receiver, but they cannot transmit as an AirPlay transmitter.
To learn which WiiM devices can function as AirPlay Receiver, see List of WiiM Devices Supporting AirPlay 2.
Important Note on Compatibility:
If you're looking to stream audio using AirPlay to your WiiM devices, the following Apple devices and software versions are compatible with AirPlay transmitters:
- iPhone, iPad, or iPod touch with iOS 11.4 or later
- Apple TV 4K or Apple TV HD with tvOS 11.4 or later
- HomePod with iOS 11.4 or later
- Mac with iTunes 12.8 or later, or macOS Catalina or later
- PCs equipped with iTunes 12.8 or later.
For those with multiple WiiM devices: You can play aux-in audio on another WiiM-connected devices, or even across multiple devices simultaneously. Detailed guidelines on this can be found here.
