AirPlay protocol doesn't support hi-res 24 bits/192kHz. Currently, the sample rate and bit depth of AirPlay is 16-bit/44.1 kHz based on either AAC or ALAC codec.
Does AirPlay stream lossless 24/192? Print
Modified on: Tue, Apr 23, 2024 at 12:20 AM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
