The Fade-In and Fade-Out feature enhances your listening experience by smoothly increasing the volume at the beginning of a track (Fade-In) and gradually decreasing it at the end (Fade-Out). This seamless transition prevents abrupt starts and stops between tracks, effectively eliminating clicks and pops.
How to Configure the Fade-In and Fade-Out Feature
By default, the Fade-In and Fade-Out feature is automatically enabled on your WiiM device without any additional configuration.
If you want to disable this feature, follow these steps:
  1. Open the WiiM Home app.
  2. Go to the Devices tab and tap the Device Settings iconof your WiiM device.
  3. Select Audio Settings.
  4. Toggle off the Fade-In & Fade-Out Effects option.
By following this tutorial, you can easily access and customize the fade effects to suit your audio preferences.
