Yes, if you're using AirPlay. It should work with Roon as the Roon endpoint. You can find more details at Roon.
For WiiM Pro owners, WiiM Pro is now Roon Ready. You can find more details on our WiiM Blog.
Modified on: Tue, Apr 23, 2024 at 12:29 AM
Did you find it helpful? Yes No
Send feedback
