The WiiM Mini remains powered on as long as it is plugged in. If you need to turn off your WiiM device, unplug it from the power source. Alternatively, if you prefer to put your WiiM device into standby mode, you can configure the standby timing through the WiiM Home app. To do this, navigate to the "Device" tab, click on the gear icon, and select "Standby Mode" to set the desired timing.
How do you turn power off? Print
Modified on: Wed, Feb 14, 2024 at 1:49 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
