The sound quality is determined by the output sample rate/bit depth and the DAC quality. Dragonfly red is the USB DAC and supports up to 24-bit/96 kHz. Compared this setup with the WiiM Mini with an external DAC via Optical port, WiiM Mini could support up to 24-bit/192 kHz output (with the latest firmware version). If the connected DAC quality is good, it can provide similar or better sound quality.
Sound-wise is this equal or better than a iPhone connected to a Dragonfly Red or a Songbird? Print
Modified on: Tue, Feb 22, 2022 at 1:31 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
