Yes, WiiM Pro can serve as the Bluetooth receiver and transmitter. If you have multiple WiiM Pros or Minis, you can simultaneously play your Bluetooth audio to a group of devices.
Note:
However, it doesn't support multiple connections of Bluetooth devices. When one device is connected, you can put the WiiM Mini into pairing mode and start to pair with it. It'll forget your previous connected device.
