Versatile Optical Input:
The WiiM Pro offers a high-quality optical input that allows you to connect diverse audio sources such as Vinyl players, TVs, or PCs. Once connected, you can effortlessly transmit the audio to another speaker within your network equipped with a WiiM device. This can be done via Wi-Fi or Ethernet, provided the devices are on the same network. Thus, you can play your physical audio throughout your house.
The digital audio transmission maintains the highest quality, offering you a pristine listening experience.
Customizable Sound Preferences:
Enhance your audio further with WiiM Pro or Pro Plus's diverse EQ settings. Tailor the sound from your optical input to suit your taste and enhance your listening experience.
High-Resolution Optical Output:
Connect your WiiM Pro to your preferred DAC, amplifier, or powered speaker using the optical output. Utilize the WiiM Pro or Pro Plus as your primary media source for streaming high-resolution audio.
Experience unparalleled sound quality with the capability to stream Hi-Res audio of up to 192 kHz/24-bit, bringing out the best in your music collection.
With WiiM Pro's optical input and output, you can create a truly customized and high-quality audio environment in your home.
