TABLE OF CONTENTS
Overview
The WiiM Voice Remote 2 is a rechargeable Bluetooth remote designed to control compatible WiiM devices. It offers the following key capabilities:
- 360° Wireless Coverage: Control playback from anywhere in the room.
- Alexa Voice Support: Use voice commands for playback control after signing in to Amazon Alexa in the WiiM Home app.
- Preset Shortcuts: Use buttons 1–4 to play your presets.
- USB-C Charging: Recharge the remote with a USB-C cable.
Compatible WiiM Devices
The WiiM Voice Remote 2 is compatible with all WiiM devices, except the following models:
- WiiM Vibelink Amp
- WiiM Sub Pro
WiiM Voice Remote 2 Controls
Each control on the WiiM Voice Remote 2 is explained below:
Standby | Press to put the WiiM device into standby mode. |
Microphone | Captures voice commands. |
LED Indicator | Displays the operational status of the WiiM Voice Remote 2. See LED Status Lights for details. |
Volume Up | Press to increase the volume. |
Previous | Press to go to the previous track or restart the current track. |
Play/Pause | Press to start or pause the current playback. |
Next | Press to go to the next track. |
Volume Down | Press to decrease the volume. |
Alexa Voice Control | Located on the right-hand side of the remote; press and hold to give Alexa voice commands. |
Mute/Unmute | Press to mute or unmute the speakers. |
Source Switch | Press to change the input source. |
Preset Shortcuts | Press buttons 1–4 to play presets. A single press plays presets 1–4. A quick double press plays presets 5–8: double-press button 1 for preset 5, button 2 for preset 6, button 3 for preset 7, or button 4 for preset 8. |
USB-C Charging Port | Connect a USB-C cable to this port to charge the remote. |
LED Status Lights
The LED indicator displays the operational status of the WiiM Voice Remote 2:
| Operation/State | LED Color/Pattern |
| Charging in progress | Slowly flashing green |
| Charging completed | Solid green |
| Button press (when paired) | White LED lights up when pressed and turns off when released. |
| Button press (when not paired) | Orange LED lights up when pressed and turns off when released. |
| Ready for pairing | Slowly flashing white |
| Pairing in progress | Rapidly flashing white |
| Pairing successful | White LED lights up for 10 seconds, then turns off. |
| Pairing failed | Red LED lights up for 10 seconds, then turns off. |
| Low battery (< 20%) | Flashes red slowly six times after each operation. |
Set Up the WiiM Voice Remote 2
Before using the WiiM Voice Remote 2 to control your WiiM device, you need to first pair it with your WiiM device using the WiiM Home app.
Video Tutorial
Step-by-Step Guide
Instructions:
- Press and hold the Source Switch and Mute buttons simultaneously for 2 seconds to put the WiiM Voice Remote 2 into pairing mode. When the LED indicator on the remote starts to flash white slowly, release the buttons.
- Open the WiiM Home app on your smartphone or tablet.
- Navigate to the Devices tab > your WiiM device's Device Settings
> Remote. - When the corresponding pop-up appears, tap Pair Your Remote to start pairing. Follow the on-screen instructions to finish the pairing process.
Alexa Voice Control
Use the WiiM Voice Remote 2 to give Alexa voice commands for push-to-talk music playback control.
- Sign in to Amazon Alexa from the WiiM Home app. For details, see How to Use Alexa with Your WiiM Device.
- Press and hold the Alexa Voice Control button
on the right-hand side of the remote to give Alexa voice commands. For more details, see What Voice Commands Can I Use with My WiiM Voice Remote and WiiM Voice Remote 2?.
For example, you can try any of the following Alexa commands:- "Play daily lift from Spotify"
- "Play my soundtrack from Amazon Music"
- "Volume 5"
- "My daily brief"
- "Play ESPN radio"
- "Play Pandora"
- Once you have finished giving your command, release the Alexa Voice Control button
, and Alexa will process your command.
FAQ
- What can I do if my WiiM Home app can't find the WiiM Voice Remote 2?
- Ensure the WiiM Voice Remote 2 has enough power.
- Press any button to check whether the LED lights up.
- Try pairing the WiiM Voice Remote 2 with your WiiM device again.
- What can I do if my device does not respond to voice commands?
- Please make sure other buttons on the WiiM Voice Remote 2 work.
- Make sure you've signed in to your Alexa account in the WiiM Home app.
- Move closer to the paired WiiM device.
- Try issuing some short Alexa commands to test if it responds.
- Besides Alexa, does it support Siri or Google voice assistant?
No. The WiiM Voice Remote 2 only supports Alexa. - Can one WiiM Voice Remote 2 be paired with multiple WiiM devices at the same time?
No. The WiiM Voice Remote 2 can only be paired with one WiiM device at a time. To use it with a different WiiM device, you have to re-pair the remote. - How can I re-pair the WiiM Voice Remote 2?
Press and hold the Source Switch and Mute buttons simultaneously for 2 seconds to enter pairing mode. Then, repeat the pairing process in the WiiM Home app.
Troubleshooting
If you are experiencing pairing failures or control issues with your WiiM Voice Remote 2, see WiiM Voice Remote 2 Troubleshooting.
