WiiM Ultra now introduces a new "Recently" feature in its touch screen menu. This feature display a chronological list of songs or radio stations played on the WiiM Ultra, with the most recent songs appearing at the top.
Currently, tracks played via a UPnP server, USB drive, or third-party apps (e.g., Spotify Connect and TIDAL Connect) are not displayed. This functionality is under development and will be available soon.
With this feature, you can quickly access and manage your recently played tracks and radio stations directly from your WiiM Ultra's touch screen. This tutorial will guide you through how to use this feature.
Benefits of the "Recently" Feature
- Instant Access: Quickly find and play your recently listened songs directly from your WiiM Ultra's screen.
- Streamlined Navigation: Avoid the extra steps of opening the WiiM Home app and navigating to the Favorites tab.
- Organized Playback History: Easily manage your listening records by removing tracks you no longer need.
How to Use the "Recently" Feature
Select and Play from Playback History
Follow these steps to play a track or radio station from your playback history:
- Tap the screen to wake up your WiiM Ultra if it is in sleep mode.
- Navigate to the home menu on your WiiM Ultra's screen.
- Tap the Recently option to view the playback history.
- Scroll through the list and tap the song or radio station you wish to play.
Delete Playback Records
Follow these steps to remove records you no longer need:
- Scroll to find a song or radio station you want to remove, then tap the
icon next to it to remove it.
Give it a try and experience a faster, more organized way to access your favorite tracks with WiiM Ultra's "Recently" feature!
