TABLE OF CONTENTS
The WiiM Pro or WiiM Pro Plus is a compact device designed to stream high-quality audio from various sources to your audio system. This tutorial will walk you through the step-by-step setup guide to get your WiiM Pro or WiiM Pro Plus up and running.
What You'll Need
- A WiiM Pro or WiiM Pro Plus device
- An external audio system, such as active speakers, a DAC, an amplifier, depending on your specific setup and preferences.
For example, if you want to stream music from the WiiM Pro or WiiM Pro Plus to your passive speakers, you will need an amplifier to power them. - A smartphone or tablet
- Wi-Fi connection
- (Optional) Ethernet connection
- (Optional) Other audio input devices you want to connect to the WiiM Pro or WiiM Pro Plus
Step-by-Step Setup Guide
1. Unbox the WiiM Pro or WiiM Pro Plus
Open the box, and you'll find the following items inside.
2. Connect the Audio Output of the WiiM Pro or WiiM Pro Plus
The WiiM Pro or WiiM Pro Plus features three dedicated audio output ports, allowing you to output audio to various external devices. You can use any of these ports depending on your setup and preference.
Line Out
The Line Out port is typically used to connect to the external audio equipment, e.g., powered speakers, amplifiers, or AV receivers to output high-quality analog audio playback.
Optical Out
The Optical Out port is typically used to connect to the external device, e.g., soundbars, DACs, or AV receivers, to output digital audio playback.
COAX Out
The COAX Out port is typically used to connect to the external device, e.g., DACs, AV receivers, or amplifiers supporting coaxial input.
3. Connect the Audio Input of the WiiM Pro or WiiM Pro Plus (Optional)
For detailed instructions, see How to Use Audio Input Ports of the WiiM Pro and WiiM Pro Plus.
4. Power on the Devices
- Connect the WiiM Pro or WiiM Pro Plus to a power source using the provided power cable.
- Connect external audio devices to a power source and power them on.
5. Download the WiiM Home App
Use your smartphone or tablet to scan the following QR code to download the WiiM Home app. The app will be used to set up and control your WiiM Pro or WiiM Pro Plus.
6. Set Up the WiiM Pro or WiiM Pro Plus
You can set up your WiiM Pro or WiiM Pro Plus through the WiiM Home app. If you’re using an iOS device, you can also complete the setup using Apple’s Wireless Accessory Configuration (WAC) protocol or the Apple Home app.
Method 1: Using the WiiM Home App
- Open the WiiM Home app on your smartphone or tablet.
- When your device appears in the app, tap Set Up to start the process.
Note: If your WiiM device doesn’t appear automatically, go to the Devices tab and tap Add Device in the top-right corner to trigger the setup page. - Follow the on-screen instructions to complete the setup process. During setup, you'll connect the WiiM Pro or WiiM Pro Plus to the Wi-Fi network, check for firmware updates, and pair the WiiM Voice Remote.
For detailed setup instructions, watch the video below.
Method 2: Using Apple WAC
- Open the Settings app on your iOS device.
- Tap the WLAN option.
- Select your WiiM Pro or WiiM Pro Plus under the SET UP NEW AIRPLAY SPEAKER section.
- Follow the on-screen instructions to complete the setup.
After setup with Apple WAC, you can use the WiiM Home app to configure your WiiM device further, including OTA updates, Room Correction, and more.
Method 3: Using the Apple Home App
- Open the Home app on your iOS device.
- Tap the + icon in the top-right corner of the screen. A new menu will pop up.
- Select the Add or Scan Accessory option from the menu.
- Select More options... in orange.
- Choose your WiiM Pro or WiiM Pro Plus from the list.
After setup with Apple Home, you can use the WiiM Home app to configure your WiiM device further, including OTA updates, Room Correction, and more.
7. Play Music
Now, stream music to the WiiM Pro or WiiM Pro Plus from the WiiM Home app or your favorite services — Spotify, Amazon Music, TIDAL, Deezer, Qobuz, and more. Or simply play from a connected audio input device. Enjoy your music with breathtaking clarity, depth, and power.
Tips and Troubleshooting
- Playback Issues: If you experience playback issues (e.g., network streaming dropouts), see General Troubleshooting Guide for WiiM Playback Issues for solutions.
- Wi-Fi Connection: Ensure your Wi-Fi signal is strong in the location where you set up the WiiM Pro or WiiM Pro Plus for a stable streaming experience.
- Ethernet Connection (Optional): For added stability, you can connect the WiiM Pro or WiiM Pro Plus to your network with an Ethernet cable instead of Wi-Fi.
- Device Not Connecting: If the WiiM Pro or WiiM Pro Plus is not connecting to your Wi-Fi, try restarting your router and the WiiM device. For details, see Troubleshooting: How to Resolve Wi-Fi Connection Issues During WiiM Setup.
- No Sound with Optical Out: If you are experiencing no sound with Optical Out during setup, see Troubleshooting: How to Resolve No Sound with Optical Out.
