No, USB-C port is only designed as the power input. You can connect it with the external dac via the TOSLINK port.
Can I output audio with an external dac through the usb-c port? Print
Modified on: Wed, Mar 2, 2022 at 11:58 AM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
