WiiM Mini can decode the 192 kHz, 24-bit lossless music files or streaming contents. When WiiM Mini supports bit-perfect function via digital optical output, it outputs the same bit depth and sample rate as your music source. I.e., if your source is 24 bit/192kHz, it will output 24/192. While if your source is 16-bit/48kHz, it outputs the same without upconversion. It uses the sample rate/bit switching to match the native file.
What is the maximum bit and sample rate from the optical SPDIF output? Print
Modified on: Tue, Jun 7, 2022 at 6:00 PM
Did you find it helpful? Yes No
Send feedbackSorry we couldn't be helpful. Help us improve this article with your feedback.
